Mounting Gas Tank In The Bed
I have a replacement tank & straps for my rusted original but I have no skid plate. An affordable skid plate is hard to find. I also don't think that the stock location is best for a truck that is going to be a toy without a skid plate. My options are to build a skid from scratch or mount the tank in a safer location. This second choice looks to be doable so...
I am thinking about using a chest-type rectangular bed tool box (free from friend) and mounting the replacement tank in the box. Such "combo tanks" that look like a truck box but use half as a fuel tank are readily available (for around $700  http://www.transferflow.com/fuel-tanks/toolbox-tank-combos ) so the idea is not original. It seems that doing this and rigging the fuel filler would be far easier/cheaper than buying an actual fuel cell with a compatible sender and getting an external pump.
Any thoughts?
Older 30lbs tanks are worthless, folks cannot give them away.
Look to an old GM for a JY filler neck.
Build one for nothing.........maybe the cost of a couple of large straps........or just weld a bracket to the bottom of the tank, horizontally, and bolt it down.
