Soa
  • Replies 58
so for the most part i know what to do for the rear. as to match the front height i know i will need the following items
- (adjustable) track bar
- (adjustable) upper control arms
- (adjustable) lower control arms
- longer brake hose
- springs
- shocks
- longer (quick disconnect) sway bar end links
where about online should i order these items, Rusty's Offroad seems to have it all but i want to know your opinions
do the control arm drop brackets make it so u can use your stock control arms?
Yes.
Although many people here say you'll want to upgrade your lower control arms at the very least. As they're pretty flimsy.
I ended up just getting a set of WJ control arms off Ebay, For about $100~. The lowers are the same length, The uppers are slightly shorter.
Havent had any problems with them, Ride quality is really nice now.
- longer brake hose
- springs
- shocks
How many inches do you plan on lifting it?
can't really do ebay. thinking more like uncle henry's or craigslist
could you possibly get a pic. of what the wj upper and lower control arms look like? ive looked online and there are so many and i don't know which ones they are
http://www.amazon.com/Omix-Ada-18282-21-Front-Control-Cherokee/dp/B0042AHET4/ref=sr_1_9?ie=UTF8&qid=1392258262&sr=8-9&keywords=grand+cherokee+lower+control+arms
http://www.amazon.com/Omix-Ada-18282-20-Front-Control-Cherokee/dp/B0042AF7Y8/ref=pd_sim_sbs_auto_1
Nice thing is, The lowers are curved a little, To help clear larger tires at full turn.
okay, i don't see what you mean by shims in the lower control arm?
 won't that bring my tires back towards the rear more and does it matter what year they come out of
You can always just get lower arms, Uppers are usually fine stock.
There are stock alignment shims in the lower control arm mount, When i added my drop bracket i removed them, to make up for the slight difference in the uppers length.
We're talking like 1/4 inch.
I THINK its 99+ Grand cherokee control arms
The shims are packed at the rear of the LCAs. Thicker shims move the wheel forward; thinner shims the opposite.
is that lists constantly updated?
i like the drop brackets but i want the ground clearance behind my tire, don't want it to be banging off rocks and getting hung up.
but what would the ride be like with just the adj. control arms? for maine pot holes.
eh, i guess either way i go i could always change it if i don't like it.
so after you do a SOA you put and angle finder on the drive shaft and make differential 2 deg. below parallel?
basically you need the rear diff. yoke to be in line with the driveshaft, only 2 deg. off for axle movement
I havent done a ton of wheeling on mine yet, Just lifted it about a month ago.
But from what i've seen/heard about it, the brackets are close enough to your tires that if your tires are going to clear the object, the bracket will be just fine.
another thought, i have a thread going about driveline angles, and I'm starting to get the drift of it.
but will this make it so my pinion yoke is too high to get proper gear oil to it. unless a crossmember drop kit is added. i have a longbed and stock driveshaft, with slipyoke. i don't want my rear diff looking like this
which leads me to another Q. what would i do with front driveshaft angle with this much lift, i have my CAD locked in so the shaft is always spinning and i don't too excessive angle on it
can't answer your first question, But the front driveline is completely fine.
I know a SYE isnt needed for 5-6" of lift though.
If you still have a slip yoke this is completely wrong!!!!!   You will have tons of drive-shaft vibrations.
When using a slip yoke style you want the pumpkin slightly down from parallel to the transfercase/transmission.   If you are using a double cardon drive line and a SLIP YOKE ELIMINATOR  (SYE)  then you want the pumpkin parallel to the drive shaft as pictured.
