chjeepin Posted January 27, 2006 Share Posted January 27, 2006 has anyone removed the regulating valvue on the back brakes before? If so how did you go about connectiong the lines? I removed it and my brakes don't seem to be funtioning top notch. Thanks Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted January 27, 2006 Share Posted January 27, 2006 There is enough information on this subject to make your head spin!!!! :D The post right above this one, (As I write this) is dealing with the same topic. http://comancheclub.com/forums/viewtopic.php?t=439 Do a search here using "REAR BRAKES". Here is one from NAXJA, using "MJ rear proportioning valve." http://www.naxja.org/forum/search.php?searchid=786073 A member EAGLE in both places has a wealth of information posted. Good Luck, CW Link to comment Share on other sites More sharing options...
512tr Posted January 29, 2006 Share Posted January 29, 2006 has anyone removed the regulating valvue on the back brakes before? If so how did you go about connectiong the lines? I removed it and my brakes don't seem to be funtioning top notch. Thanks I removed the stock prop.valve, and for me it works good without the valve. I do not have any problems that the rear locks before the front brakes, have been driving only on snow and ice since I removed it. The rear is a D44 with 10" drums, here's how I did the lines.. Link to comment Share on other sites More sharing options...
pingpong Posted January 29, 2006 Share Posted January 29, 2006 I'm looking at what you did, and basically you put a t-connector in before the valve and ran new hardline from there back? Thats cool, I swapped mine over to a XJ prop valve, for the simple fact that it was easier, and my rear lines were rusted thjrough in various spots. Patrick Link to comment Share on other sites More sharing options...
87manche Posted January 29, 2006 Share Posted January 29, 2006 mine is done like 512's, only not nearly that nice. I did the t right at the valve, and secured it to the pro vavle mount. I was going to take pics this wekend, but it's raining, and cold. So you're out of luck today. Link to comment Share on other sites More sharing options...
