Another Valve Cover Thread
So while going over my new comanche, I found that the po has really hacked together the front CCV line. When trying to investigate the hose 'repairs' the entire 90* fitting has broken and almost fell into the valve cover, I am planning on soonish replacing the entire valve cover with the one from my 95 XJ but I need to get the MJ road worthy and put it through the state salvage inspection before I can tear into the XJ. Is there any acceptable way to repair this such as putting a new fitting in the valve cover and just using rubber hose for now instead of the factory stuff? I have a few extra CCV fitting that I bought awhile ago for the XJ, if those will work?
Well, tomorrow morning I am going to remove the valve cover and replace the existing parts with these + new grommets then using rubber hose to replace the existing brittle plastic pieces, I hope they will work out.
They should do it I got mine thru napa years ago so I do not know the number. I can get a pic mine if you want also you will need increase the dia of fitting in the manifold that the breather hose goes to I just used a standard air hose fitting the thread is the same. One like this You can get one most anywhere.
http://www.ebay.com/itm/Brass-1-4-ID-Hose-Barb-1-4-NPT-Fitting-Coupler-Air-Fluid-Fuel-Gas-Liquid-Water-/111029553513?pt=Pneumatic_Hydraulic_Valves_Parts&hash=item19d9e08969
Checking back in after doing this job, so everyone knows the fittings pictured above do not work with the renix valve cover, I found this out half way through the job. I filed down the new fitting and used silicone to seal it back up properly. I am doing this temporary as I plan on swapping over my 95 valve cover when i start to tear into the 4wd swap.
