big66440 Posted January 10, 2014 Share Posted January 10, 2014 I'm going to be replacing my timing set this weekend and installing a replacement harmonic balancer from Mopar but it says the oil slinger can not be used with this updated part, I know what it's for but do you guys think it will be a big deal to run my truck without it? I have an 89 base 4.0/AW4 2WD, thanks. Link to comment Share on other sites More sharing options...
87Warrior Posted January 10, 2014 Share Posted January 10, 2014 The slingers main purpose is to act as a shim between the crank and balancer. The new Mopar balancer does not need this shim. There was a similar topic about a month ago regarding the balancer and oil slinger. Link to comment Share on other sites More sharing options...
