jimoshel Posted January 7, 2014 Share Posted January 7, 2014 I'm replacing the slave cylinder, or trying to. They got the correct cylinder in the package but the wrong instructions. The two plastic, nylon? straps holding the cylinder compressed. Should they be cut, removed after installation, or not. Does the first clutch operation break them? '90 MJ, 4.0, AX15. The book just doesn't say. Tnx in advance, Jim :dunno: Link to comment Share on other sites More sharing options...
yxmj Posted January 7, 2014 Share Posted January 7, 2014 I just snip mine at the last minute when I am sliding the trans when I can still get at them. Never thought about breaking them with the first clutch pump.......I wonder if that would work :dunno: EDIT....The google machine says you can leave them on...http://www.jeepforum.com/forum/f12/internal-slave-cylinder-question-736063/ http://www.jeepforum.com/forum/f12/slave-cylinder-installation-internal-183255/ Link to comment Share on other sites More sharing options...
48MJ Posted January 7, 2014 Share Posted January 7, 2014 I believe if I remember correctly they stay on and beak when clutch is first depressed. I cut mine and everything worked right but then read the directions later on and they said to leave the on. Link to comment Share on other sites More sharing options...
jimoshel Posted January 7, 2014 Author Share Posted January 7, 2014 Never thought to Google it. Good reading. Now I'm wondering why I'm messing with a internal slave when I have couple external set ups. Looks like I'm going to change horses in the middle of the stream. Link to comment Share on other sites More sharing options...
