Jrwhite3230 Posted December 31, 2013 Share Posted December 31, 2013 my tail light's not working although my headlights and blinker works ,also short in the fuse block (park number# 10 amp fuse keeps shorting out blowing the fuses?. I also am trying to find out which rear light is what ? does the brake light the same bulb as the blinker ? and the tail lights work seperatly ,or does tail light share the headlight circuit?? also what color is the wire for the tail lights? i have gone through every inche of the harness and haven't found anything that would cause a short except that fuse at fuse block which I'm not sure is the correct circuit ill post photo's of what i have thanks for any reply Link to comment Share on other sites More sharing options...
NHMJXJ Posted December 31, 2013 Share Posted December 31, 2013 Taillights and dash lights share the same fuse. Have you got dash lights? Link to comment Share on other sites More sharing options...
Spectormj Posted December 31, 2013 Share Posted December 31, 2013 also check your wires happened to me it was wires Link to comment Share on other sites More sharing options...
Jrwhite3230 Posted January 1, 2014 Author Share Posted January 1, 2014 ive checked them all the way to fuse block so far no suspects! it's an all point's bulletin shorty and sparky on the run,i have checked the local hangout's but it's a no go the bulb's all are ok. is the bottom light the running light? (taillight) or does it come on with the brake light and just gets brighter when brake is depessed? thanks for reply Link to comment Share on other sites More sharing options...
