BARILLMS Posted April 16, 2007 Share Posted April 16, 2007 I'd like to put my gas tank in the front of my bed. What all do I have to do? Link to comment Share on other sites More sharing options...
mjcanoe Posted April 17, 2007 Share Posted April 17, 2007 BARILLMS, I"ve not done it on my MJ, but on others. You can contact JEGS, SUMMIT, or other speed shops for a certified fuel cell that might fit your needs. As long as you use f/pump with proper PSI specs & secure cell & route lines safely, no problems. You may want to consider a barrier or safety wall of some kind if you carry a lot in your bed. mjcanoe Link to comment Share on other sites More sharing options...
Rokhound Posted April 17, 2007 Share Posted April 17, 2007 http://www.comancheclub.com/forums/view ... 57&start=0 here is one that i found right quick Link to comment Share on other sites More sharing options...
feerocknok Posted April 17, 2007 Share Posted April 17, 2007 I've done it on a Toyota before. Make sure you get the tank high enough to clear the d-shaft, but try to keep it low enough to not kill your CoG. Also, try and keep the exhaust away from it. And, yes, build a cover for the stock tank. You don't want to risk puncturing it. Link to comment Share on other sites More sharing options...
