Bornindesert Posted December 19, 2013 Share Posted December 19, 2013 Does anyone know what tool is used to remove this plug? It's not 3/8" extension friendly. Link to comment Share on other sites More sharing options...
yxmj Posted December 19, 2013 Share Posted December 19, 2013 10 MM If you do not have access to a 10mm extension you might be able to find the right size in "key stock" and use an adjustable wrench on the end Link to comment Share on other sites More sharing options...
Comanchemodder Posted December 19, 2013 Share Posted December 19, 2013 If you are one of those guys who demands the right tool for the job: A 10mm "plug socket" http://www.ebay.com/itm/TWO-PIECE-8MM-10MM-SQUARE-DRAIN-PLUG-SOCKET-SET-2049-3-8-DRIVE-/190827325135?pt=Motors_Automotive_Tools&hash=item2c6e31e6cf&vxp=mtr Link to comment Share on other sites More sharing options...
jimoshel Posted December 19, 2013 Share Posted December 19, 2013 It's close to a 20 mile drive for me to the auto parts store. I was in a hurry so I cut up a tin can and wrapped a strip around the end of a 3/8 drive extension. It worked. Link to comment Share on other sites More sharing options...
yxmj Posted December 19, 2013 Share Posted December 19, 2013 It's close to a 20 mile drive for me to the auto parts store. I was in a hurry so I cut up a tin can and wrapped a strip around the end of a 3/8 drive extension. It worked. :thumbsup: :thumbsup: 2 thumbs up.... A bit of grinding or filing on a bolt with a 1/2" shank would give you a square end that you could use a wrench on :dunno: Link to comment Share on other sites More sharing options...
Bornindesert Posted December 19, 2013 Author Share Posted December 19, 2013 Measured it and it's 8mm or .320" but there are probably 10mm versions of this plug. I think i'll roll over to AutoZone later and see if they have any plug sockets. I don't have any hardened 1/2" bolts with a shank, just threads but that would have been my first choice. Thanks for the leads! Link to comment Share on other sites More sharing options...
