Fuel Pump 89 Jeep Comanche 4.0 6Cyl
I am having a tough time trying to locate a new fuel pump for my 89 jeep Comanche its 4.0 6cylinder I replaced the  fuel tank (spectra) with the pan to the left and could not find a new rack (sending unit) which the sock goes to the left into the pan the pump is all I need but I can't find the correct pump not knowing the right part number and its pressure specifications does anyone know or can guide me in the right direction? also the pump is the larger version that has two rubber holding boots that fit it securely to the sending unit .thank you for any assistance
