kq.echo.413 Posted December 14, 2013 Share Posted December 14, 2013 Ok I have been working on my 89 pioneer comanche 4.0..I have changed the headlight switch regrounded the dash harness and checked all lights in the cluster.But I still have both turn signal on dash lighting up like there is a issue somewhere else.Any ideas would be helpful.. Link to comment Share on other sites More sharing options...
nitroxsteve Posted December 14, 2013 Share Posted December 14, 2013 All the time? With lights on or off? When did it start? Link to comment Share on other sites More sharing options...
Eagle Posted December 14, 2013 Share Posted December 14, 2013 Replace both front turn signal sockets. Your sockets are bad, and the lights are grounding by backfeeding through the dashboard. Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 14, 2013 Author Share Posted December 14, 2013 Nitro.. I just bought this one .it had lots of issues but I have narrowed it down to just the to lights on the dash. It only happens when I turn on my head lamps Eagle I will try the signal buckets ..or can I reground them to chassis Link to comment Share on other sites More sharing options...
nitroxsteve Posted December 14, 2013 Share Posted December 14, 2013 On 12/14/2013 at 9:27 AM, kq.echo.413 said: Nitro.. I just bought this one .it had lots of issues but I have narrowed it down to just the to lights on the dash. It only happens when I turn on my head lamps Eagle I will try the signal buckets ..or can I reground them to chassis what eagle is telling you is very common and I am sure will fix your problem. No re ground needed just new sockets. Link to comment Share on other sites More sharing options...
Eagle Posted December 14, 2013 Share Posted December 14, 2013 On 12/14/2013 at 9:27 AM, kq.echo.413 said: I will try the signal buckets ..or can I reground them to chassis Won't help. The sockets are bad internally. Replace. Been there, done that. And don't even think about junkyard sockets. This is a known issue with XJs and MJs -- why replace one 25-year old part with another 25-year old part that has the same problem? There is a socket marked for some Ford vehicle that's usually available in the Dorman "HELP!" parts line at all the parts chains that fits the XJ/MJ light housings perfectly. Unfortunately, I don't remember the part number. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted December 14, 2013 Share Posted December 14, 2013 :agree: 100 % Been there done that. Definitely support the use of NEW front turn signal sockets. Link to comment Share on other sites More sharing options...
Oyaji Posted December 14, 2013 Share Posted December 14, 2013 Also, whenever you are doing an electrical repair, it is a good idea to break out the soldering iron and shrink tubing instead of relying on crimped connections. It takes a wee bit longer, but the repair won't fail because of a corroded or loose connector later... Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 14, 2013 Author Share Posted December 14, 2013 Thank you guys... I am on the hunt for light sockets..I will keep you posted Link to comment Share on other sites More sharing options...
Comanchemodder Posted December 16, 2013 Share Posted December 16, 2013 I had the same issue. Both dash arrows light up when headlights are on. I changed the sockets and problem solved. Signals and dash lights work exactly as should. Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 16, 2013 Author Share Posted December 16, 2013 I did find metal bucket light sockets that would fit at my local parts store.. The lights work perfect now ..thank you guys for the knowledge Link to comment Share on other sites More sharing options...
kq.echo.413 Posted December 16, 2013 Author Share Posted December 16, 2013 On 12/14/2013 at 3:08 PM, Oyaji said: Also, whenever you are doing an electrical repair, it is a good idea to break out the soldering iron and shrink tubing instead of relying on crimped connections. It takes a wee bit longer, but the repair won't fail because of a corroded or loose connector later... Link to comment Share on other sites More sharing options...
