Both Turn Signals On Dash
Nitro..
I just bought this one .it had lots of issues but I have narrowed it down to just the to lights on the dash. It only happens when I turn on my head lamps
Eagle
I will try the signal buckets ..or can I reground them to chassis
what eagle is telling you is very common and I am sure will fix your problem. No re ground needed just new sockets.
Won't help. The sockets are bad internally. Replace.
Been there, done that.
And don't even think about junkyard sockets. This is a known issue with XJs and MJs -- why replace one 25-year old part with another 25-year old part that has the same problem? There is a socket marked for some Ford vehicle that's usually available in the Dorman "HELP!" parts line at all the parts chains that fits the XJ/MJ light housings perfectly. Unfortunately, I don't remember the part number.
Also, whenever you are doing an electrical repair, it is a good idea to break out the soldering iron and shrink tubing instead of relying on crimped connections. It takes a wee bit longer, but the repair won't fail because of a corroded or loose connector later...
