mjaddict90 Posted December 12, 2013 Share Posted December 12, 2013 Just curious as to anyone else running into this problem also, my heater stopped working a few months back and I cannot figure out what the hell is wrong with it. ive already changed all fuses, I did hook the blower motor up to the battery just to test it and yes it did work. the only setting was high or nothing. I checked relays, traced wires and have yet to find the problem. what do I do??? Any help is appreciated , thanks:) Link to comment Share on other sites More sharing options...
Pete M Posted December 12, 2013 Share Posted December 12, 2013 I'd bet the resistor pack is bad. :thumbsup: it's located in the ductwork under the dash on the passenger side right above the passenger's left foot. comes out with an 8mm wrench I think. the reason high speed still works is that that's the full 12 volts. all other settings go through the resistors to drop the voltage and drop the fan speed. Link to comment Share on other sites More sharing options...
skel130 Posted December 12, 2013 Share Posted December 12, 2013 ^^ X2 Link to comment Share on other sites More sharing options...
mjaddict90 Posted December 12, 2013 Author Share Posted December 12, 2013 soo would that be a part I could replace at the local scrap yard? or should I try an find a new one? Link to comment Share on other sites More sharing options...
Blue XJ Posted December 12, 2013 Share Posted December 12, 2013 A new one should cost you about $12. I'd go that route instead of buying another used one. There is an A/C version and non A/C version (at least there was for my 90), the connector looked a little different, so make sure to get the correct one. Link to comment Share on other sites More sharing options...
