Swaping Renix Gauge Questions
It is possible on most older gauge clusters, but it can be very delicate and tedious work.  I am unfamiliar with these trucks specific cluster setup to give you an actual opinion on it, but I did this same thing on two other vehicles of similar vintage.  I was able to remove the needles, face plate, and access the odometer/trip rollers from the front.  I had to go buy a set of jewelers screw drivers to do this.   Hopefully someone who is more knowledgeable about these clusters chimes in.
Easy to do. I helped a friend swap a cluster with a tachometer into his truck -- the "new" one had much higher mileage, so we swapped the original speedo into the new cluster. Each speedo is held into the cluster by only two (three?) screws.
