Dirteatr717 Posted November 26, 2013 Share Posted November 26, 2013 Short story- Driving my 87 home from work yesterday and slammed on my brakes because someone cut me off and then slammed on their brakes to stop at a yellow light. I had all 4 tires locked up skidding sideways... Ever since I've had to pump the pedal 2-3 times for it to have decent stopping power. I checked all the lines and cylinders for leaks and couldn't find any, there haven't been any puddles or drops anywhere either. Could I have blown the vacuum seal inside the booster? It makes a hissing sound louder than usual but I still have working brakes after pumping the pedal 2-3 times! I need to figure this out because now I have 2 Jeeps I can't drive :( Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 26, 2013 Share Posted November 26, 2013 Yep........they do go bad. Link to comment Share on other sites More sharing options...
AeroNautical Posted November 26, 2013 Share Posted November 26, 2013 I have to pump my brakes twice to get full stopping power after changing my axle. It was much worse, but I bench bled the master in the vehicle and it helped alot, but still needs a pump. Is this a sure sign of a bad booster? Link to comment Share on other sites More sharing options...
Eagle Posted November 26, 2013 Share Posted November 26, 2013 Check your hard lines, especially over the gas tank, and check your rear height sensing valve. It was a panic stop just such as you describe that exploded the height sensing valve in my '88 MJ. The result is that you get a low pedal because the rear circuit is blown and you are now stopping entirely with the fronts. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted November 26, 2013 Author Share Posted November 26, 2013 I checked everything from the booster to the rear wheel cylinders and there's no leaks, 99% of the truck is rust free so none of the lines are rotted. I did the chilton brake booster test and seems like my booster is shot, I have a 99 XJ booster and master I can modify to fit so that'll be this week/weekends project.. Link to comment Share on other sites More sharing options...
Jeep Driver Posted November 26, 2013 Share Posted November 26, 2013 I checked everything from the booster to the rear wheel cylinders and there's no leaks, 99% of the truck is rust free so none of the lines are rotted. I did the chilton brake booster test and seems like my booster is shot, I have a 99 XJ booster and master I can modify to fit so that'll be this week/weekends project.. You stated that there was additional 'hissing' after the panic breaking.......that was the tell tale......but you got it figured out anyway. I replaced my booster with a new stock one last year and I wish I had done the later model upgrade. Link to comment Share on other sites More sharing options...
