Jester1341 Posted November 12, 2013 Posted November 12, 2013 Have a 1986 with the 2.5 i4 AX4 with new clutch and new slave. Had a seized engine from HG failure. Swapped for a '94 wrangle block but kept the single point injection for ease of swap. Floor pans have some rust and bed has rust on outer panels. Frame is solid and underside is in pretty great shape. Comes with gas skid, plastic bed liner, and old engine(if you want) Truck is a nearly road ready project but will need at least a block off plate and probably starter. 1300 OBO I'm open to trades also. I don't want to get rid of this but I just won't have time to get to it soon since I just moved.
onlyinajeep726 Posted November 12, 2013 Posted November 12, 2013 Does it come with the bed mounted speaker there? :brows: Haha
richasco Posted November 15, 2013 Posted November 15, 2013 What would the "block off plate" be for, and what is the seat situation? Also forgot, how's the tread on the tires? Thanks
Jester1341 Posted November 19, 2013 Author Posted November 19, 2013 I used a '94 engine as the replacement but kept the '86 intake for the single point injection. There is an EGR on the intake but it won't hook to anything on the exhaust mani so it would need a plate so it isn't a huge vacuum leak. The tires are not what I would call 'good' but the hold air just fine and do have some tread. If you wanted to pass an inspection with them I wouldn't promise that.... But you could 'use' them. John
Jester1341 Posted November 19, 2013 Author Posted November 19, 2013 Sorry I have the stock bench seat it is actually in pretty great shape. Tan John
Archived
