My Mj Biuld
its a 88 comanche
it was a shortbed 4.0 renix stickshift with the cheap tranny not even the ax15 2wd also
now its a 4.0 HO with a auto tranny 4x4
the engine was fully rebuilt using my stock block and crank and rods
the rest was my way i bored it out put vortec 5.7 pistons with a 7120 head which was ported nd + size valves
i used the vortec 6.0 valves with heavy duty spring kit that came with the lunati cam i put in it also. intake manifold nd
throttle body also bored to match the head. i run it on 91 pump gas with a 150 shot of nos.
tranny is off a 2000 cherokee its modified also has a shift kit drivetrain i run 3.73 gears with 31x10.50r15 km2's
