Xj Country Door Panels And Cluster Bezel Tn
relyt120
I have two sets of XJ country door panels with armrests, I also have the wood grain cluster bezel that goes with them.
Will post up pics as soon as I get them cleaned up a bit.
Asking $90 plus shipping for a set including both front door panels, arm rests, map pocket, and the cluster bezel.
$70 for just a set including both front door panels, arm rests, map pocket without the cluster bezel
$20 each for woodgrain cluster bezel.
Shipping is an option at buyers expense.
Thanks for looking!
They actually just attach to the door itself, they latch on the top and have 3 clips similar to the door panels. The panels are shorter to accommodate the trim.
Ah, okay. Thanks. So those pieces would not work on a normal door panel unless it was trimmed down?
Archived
