1991 Comanche Gauge Cluster Swap
Hello and thanks in advance I'm sure this has probably been discussed just couldn't find any info..
I have a 1991 Comanche with idiot light gauges and need to replace them with actual needle gauges. Will 1991 Cherokee clusters work? There seems to be more Cherokees avaliable at the junkyards. I know I have to replace the oil and temp switches.
Thanks!
1991-1996 cluster from a cherokee should work. just make sure you get one from a vehicle with a like engine as yours, and get those sensors. it should be a direct swap, an easy one too with no speedo cable to break.
