swamprat Posted September 2, 2013 Share Posted September 2, 2013 I bought a new harness for my comanche, and its different than my factory one. only thing I can think of is my jeep doesn't have factory trailer wiring and the harness does. Does anyone have a diagram of both harnesses so I could merge the two? Link to comment Share on other sites More sharing options...
relyt120 Posted September 2, 2013 Share Posted September 2, 2013 The only difference should be between Renix and HO MJ's where I believe they simply have a different connector. So far as I know, which may not be far at all, any trailer harness had to be spliced into the factory harness. Can u post details of the truck you got the harness from and the truck u want to put it into? perhaps a pic? also you can find the info u need here: http://comancheclub.com/topic/19339-trailer-wiring-for-4-wire-and-6-pole-receiver/?hl=trailer+wiring Link to comment Share on other sites More sharing options...
swamprat Posted September 2, 2013 Author Share Posted September 2, 2013 My truck is a 92 sport, the donor is a 89 Pioneer. Link to comment Share on other sites More sharing options...
relyt120 Posted September 2, 2013 Share Posted September 2, 2013 There's your problem, Chrysler changed the plug for the tail light harness when they switched to the HO. You should be able to swap the plug on the rear harness side if you like or someone may sell you a tail light harness with the correct plug. There is a 91 in my local JY now. If you want I can snatch either the whole harness or just the plug for the tail light side the next time I'm there. PM me if you want to go that route. Link to comment Share on other sites More sharing options...
swamprat Posted September 2, 2013 Author Share Posted September 2, 2013 as long as the color codes are the same between the years, i can swap them. i've already got the bed off and ready to install my straight one. and the donor wasnt factory trailer wiring. it was a really clean and good wiring job. Link to comment Share on other sites More sharing options...
swamprat Posted September 2, 2013 Author Share Posted September 2, 2013 colors are different from renix to HO, looks like i need to do some more digging Link to comment Share on other sites More sharing options...
swamprat Posted September 2, 2013 Author Share Posted September 2, 2013 for future reference, HO tail light wiring: Black - ground Brown/Green - back up lights Blue/Red - running lights (parking) pink (salmon) - brake & right turn signal Green - brake & left turn signal Renix taillight wiring: Brown: Right turn and brake lightBlack: GroundBlue: Tail (parking) lightsBrown with white tracer: Backup lightGrey with black tracer: Left turn and brake light so renix to HO plug convertion would go as such: Black - black Brown/Green - brown/white Blue/Red - blue Pink - brown Green - grey/black Link to comment Share on other sites More sharing options...
relyt120 Posted September 2, 2013 Share Posted September 2, 2013 are you going to hardwire in the harness or do you also have the rear harness side of the plug to change over? Link to comment Share on other sites More sharing options...
swamprat Posted September 3, 2013 Author Share Posted September 3, 2013 i had the plug to change over, i had the full HO harness it was just hacked to hell by the previous owner ghetto rigging it after the accident. Link to comment Share on other sites More sharing options...
relyt120 Posted September 3, 2013 Share Posted September 3, 2013 oh good, as you can probably tell hard wiring the tail light harness to the rear harness would make bed removal problematic. Link to comment Share on other sites More sharing options...
Crash Posted May 24, 2015 Share Posted May 24, 2015 I know this thread is older, but it was a help as far as wiring for me. The colors of the wires matched up just fine, but the connectors were different. I just ended up splicing into the 87 bed harness with the harness that was already on the truck. The bed I currently have is from my 87 project MJ. The rear section of the harness that connected to the tail light harness was a 6-pin GM weather pack connector with the 5 wires. The front harness connector from the 87 looks lightly different than what was connected in the cab. My truck is an 88, and the rear connector at the tail light end was more of a square-ish connector type. Since the back side of that was already cut into for the "trailer lights" I just connected those and spliced the wires in to the wires after the 87's GM weather pack connector. I would like to eventually make the whole setup more solid. The questions I have are. Where the harness than runs from the cab to the back, are the connectors the same 87-88? And I just assumed that they were different? Or are both ends of the connectors different, and I need to figure out "WTF" ? The main harness to the rear from the 87 is intact and sitting in a box of parts. IF the front harness connector is the same I can/will just swap the intact harness and call it good. Another thought on the matter is, if the connectors in the cab really are different, cut and splice the harness at the rear to keep the GM 6-pin connector? And 3rd, maybe find someone to trade, or buy a correct harness that works? Link to comment Share on other sites More sharing options...
relyt120 Posted May 24, 2015 Share Posted May 24, 2015 all renix connectors 87-90 should be the same for the rear harness unless a PO changed it out. Link to comment Share on other sites More sharing options...
