Tow Hooks
They fit, everything from the cab forward is the same between XJ and MJ. The differences start at the back of the cab, and specific things like cross member location on the floors and seat brackets.
Several companies make some brackets for the XJ/MJ that you can use D-rings instead of tow hooks as well.
I went and got 6 bolts, M10-1.5*45mm because the OEM bolts were too short. Agree bolts right on to the factory hole pattern. Not sure why exactly but I notched my air dam so i could turn the hook up. Check your sway bar for clearance as the bolts stick out further. It's a nice add on for the factory bumper.
Just a consideration, but the brackets are substantial in terms of steel, fabrication and machining. The hooks are forged. I got some hardware when I picked mine up, specifically the bolts that attach the hooks. In terms of value and the fact that you can really hook up and get pulled out of a tough spot without having to worry about the location of the pull...kinda worth $75. I don't think it's a smoking deal, but definitely a good deal.
