Mystery Wire (Harness)
I found this in my MJ 3 years ago when I was putting the interior back together.
Anybody got an idea what it's for. I thought it may have something to do with factory mini-tweeters (which it doesn't have), but the wires for my XJ mini-tweeters (which it DOES have) look nothing like this/these.
Whole thing
One end
Other end
onlyinajeep726, you are correct. I installed an XJ power antenna in my MJ a few years ago, but did not document the wiring diagram. But from memory, the 4-pin connector goes to the antenna relay, the 2-pin to the power antenna, and the small spade connector goes to the radio power antenna output terminal; the other to ground. It is a factory part, as that harness came with the power antenna.
