AeroNautical Posted August 20, 2013 Share Posted August 20, 2013 I'm trying to diagnose a problem I've been having with my electrical, and I'm pretty sure I've narrowed it down to the alternator. Just had the battery checked and the cells are good. I'll list the issues, and maybe you guys can confirm it's the alt: My volt meter reads low at idle, around 11 or 12 At higher rpm, it reads just under 14. If my headlights are on and I hit the brakes, they dim If I have a turn signal on at idle, the volt meter fluctuates. If the battery is disconnected, the engine dies I think that's enough to go on to diagnose it. I also have a question about the alternator I should pick up. There are quite a few options ranging from 60 to over 100 amps. I've got external lights and a few high demand accessories, but don't have an A/C or any of that fancy stuff. Would it be a wise investment to grab a higher amp alt? Any brands better than others? I've heard alot of times alts are doa, I'd like to avoid that as much as possible, especially if I'm ordering online. Help is appreciated, as always. Link to comment Share on other sites More sharing options...
azdiesel Posted August 20, 2013 Share Posted August 20, 2013 Check out Delco aftermarket new alternators. I was offered one for my comanche for $89.00 outright. There is a model with single wire output and they exciting. I was told they also have roller bearings, not ball bearings. They have several different configurations and up to 200amps. Perhaps you can find one that works for you. Link to comment Share on other sites More sharing options...
yxmj Posted August 21, 2013 Share Posted August 21, 2013 If the battery is disconnected, the engine dies That one line gives you your answer.....once started your engine should run without the battery being connected..... IMHO....stick with Jeep parts....Try finding a 1997 V8 one......There were some rated at 136 amps http://www.jeepforum.com/forum/f9/97-98-136-amp-alternator-swap-1226669/ Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 21, 2013 Share Posted August 21, 2013 If the battery is disconnected, the engine dies That one line gives you your answer.....once started your engine should run without the battery being connected..... IMHO....stick with Jeep parts....Try finding a 1997 V8 one......There were some rated at 136 amps http://www.jeepforum.com/forum/f9/97-98-136-amp-alternator-swap-1226669/ Hard to do in a Renix.......... Link to comment Share on other sites More sharing options...
yxmj Posted August 21, 2013 Share Posted August 21, 2013 If the battery is disconnected, the engine dies That one line gives you your answer.....once started your engine should run without the battery being connected..... IMHO....stick with Jeep parts....Try finding a 1997 V8 one......There were some rated at 136 amps http://www.jeepforum.com/forum/f9/97-98-136-amp-alternator-swap-1226669/ Hard to do in a Renix.......... Nothing is impossible.....if you want it bad enough :thumbsup: http://greatlakesxj.activeboard.com/t38048063/renix-xj-with-v8-zj-136amp-alternator/ Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 21, 2013 Share Posted August 21, 2013 Who said anything about impossible? You need new HO brackets, belt, regulator, and ND alternator. Cheaper and easier to bolt on a built-up Delco. Link to comment Share on other sites More sharing options...
comanchedude Posted August 22, 2013 Share Posted August 22, 2013 just get the 100 amp factory unit. it will power all the stuff you need...and its a drop in rock auto has them right now for $ 40.00 ACDELCO Part # 321352 {#10463035, 19135907} Reman; 100 Amps DELCO SERIES CS130; w/A/C [Wholesaler Closeout - Link to comment Share on other sites More sharing options...
TCAdkins Posted August 22, 2013 Share Posted August 22, 2013 My alternator just went out a couple of weeks ago. My symptoms were: - Battery died while wheelin, jumped it and truck would die 2 minutes after it had been jumped and charged a little. - No turn-signals at all - Radio started sounding like $#!&. (It's a brand new stereo and sounds pretty good. All of a sudden it sounded like 4 cheap ipod speakers were in my truck.) We go wheelin behind walmart so I parked it in the walmart parking lot and grabbed an alternator the next day. Couldn't get the skid plate off, so I got towed to a buddy's house and we replaced it there, took about an hour. Truck runs great now, turn signals work, and radio sounds good again. As far as amps go, I bought a 60 and I'm planning on running 4 KC's. The stock was some disgraceful number like 44 I believe. So I think just the extra 16 amps should help a bit. Link to comment Share on other sites More sharing options...
