How To Post A Video Clip?
In Photobucket:
Go to your photo/video library.  Select the video...but don't open it.  In the upper right hand corner of the video file, there's a little "gear" looking thing.  Right click on that.  A menu screen will appear that, at the bottom of that it will say "get links".  Click on that, another menu screen appears, at the bottom it says IMG code, click on that and it will say "copied".  Then go back to your post in CC.  Click on the main screen once, then right click and hit PASTE.  The *img* code will appear, not the video, but when you POST your post it will appear.
If it does not come up when you post it, you can go to edit and try it all over again.  Hope I explained that OK...good luck.
