Parasitic Draw
I'm fairly new to jeep ownership however recently I've fell into an issue with the battery which is less than a yea old dying out on me overnight.  So I charged my battery back to full, grabbed my multimeter and began searching for a parasitic draw on the battery.  After I turn off the truck I use the black which is hooked up to com to the negative battery terminal and the red on the negative cable.
My current DC reading is around 12.4-12.5 while the truck is off.  It seems as though I have everything connected the way I was told but 12 amps seems really high.  Anyway I've found that there is a little device towards the front that is setting it off.  Can anyone identify this box?  its not affiliated with the main battery line but there are a lot of wires coming out of it.
