Holy moly!
3-5/8" backspacing, and an 8" rim? You're going to have a LOT of rubbing with that setup. The inner rim/bead is going to be an inch and a half farther outboard than stock rims, and then add another inch of wheel width and suddenly your tires are going to sit two and a half inches farther out than stock. You won't rub the control arms, but I'll almost bet you'll be hitting the flares when you [try to] turn, and the tires will whack the flares when the suspension compresses.
