hey guys i was driving today and came across a problem after pulling a person out of a mile long mud pit.
It seems that my transmission is downshifting on  me and locking up my rear locker causing it to be hard to drive  it will down shift hard and sometimes seems like its out of gear fluid level looked right and clean
 the jeep is a 87 metric ton already did the TV cable reset
anything helps as i use this truck for work
i might just be nuts also on the locker part the locker is almost brand new but i will check that out also should add it is jumping to like 4k rpms and higher when downshifting  and it surges in gear and will jump 500 rpms and go up and down
Now that sounds like a trans issue.
Unplug the speed sensor off the transfer case. Clean out any crap in the connector. Do the same with the trans connectors in the engine bay. click on the link in my signature and there some instructions with photo on the plugs in the engine bay.
