87manchenick Posted June 25, 2013 Posted June 25, 2013 hey guys i was driving today and came across a problem after pulling a person out of a mile long mud pit. It seems that my transmission is downshifting on me and locking up my rear locker causing it to be hard to drive it will down shift hard and sometimes seems like its out of gear fluid level looked right and clean the jeep is a 87 metric ton already did the TV cable reset anything helps as i use this truck for work
cruiser54 Posted June 25, 2013 Posted June 25, 2013 Trans won't cause a locker to do anything. Maybe there's a problem with the locker?
87manchenick Posted June 25, 2013 Author Posted June 25, 2013 i might just be nuts also on the locker part the locker is almost brand new but i will check that out also should add it is jumping to like 4k rpms and higher when downshifting and it surges in gear and will jump 500 rpms and go up and down
cruiser54 Posted June 25, 2013 Posted June 25, 2013 i might just be nuts also on the locker part the locker is almost brand new but i will check that out also should add it is jumping to like 4k rpms and higher when downshifting and it surges in gear and will jump 500 rpms and go up and down Now that sounds like a trans issue.
87manchenick Posted June 26, 2013 Author Posted June 26, 2013 my dad confirmed today that it is not the locker when it downshifts it scares me and a swerve left and yes we have it down to a trans problem
cruiser54 Posted June 26, 2013 Posted June 26, 2013 Unplug the speed sensor off the transfer case. Clean out any crap in the connector. Do the same with the trans connectors in the engine bay. click on the link in my signature and there some instructions with photo on the plugs in the engine bay.
