skidoo_j Posted June 24, 2013 Share Posted June 24, 2013 Looking for a dana 44 carrier with 3.92 and up could be with or w/o trac loc style. Also in need of some 4.10 reverse cut d44 ring pinion. Link to comment Share on other sites More sharing options...
87Warrior Posted June 24, 2013 Share Posted June 24, 2013 FYI, you could use a 3.92 down (numerically lower) carrier with thick cut 4.10 gears. This is how the TJ Rubicon is built. I believe Don (Hornbrod) runs a similar set up. Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 24, 2013 Share Posted June 24, 2013 Yes I do. :yes: 4.10 D44 with Yukon "thick" gears, Honda Passport Trac-Loc limited slip 2.72 - 3.73 carrier. No problems. Link to comment Share on other sites More sharing options...
skidoo_j Posted June 24, 2013 Author Share Posted June 24, 2013 It's going in a High pinion. I havn't found "thick" reverse cut gears. Who makes them? Link to comment Share on other sites More sharing options...
HOrnbrod Posted June 24, 2013 Share Posted June 24, 2013 It's going in a High pinion. I havn't found "thick" reverse cut gears. Who makes them? Ah okay - understand now. Nobody makes them that I've been able to find. Link to comment Share on other sites More sharing options...
