I Unbolted Everything And Cutting The Rest Of The Mj Up. Who Needs Pieces? Massachusetts $200?
87sparTruck
Like I said I'm cutting up the cab of the truck.  I'm saving the floor.  Everthing else is gone and anything left can be cut out.  No bed, back window, and the back half of the frame has crumbled.  No Header panel fenders are rotted but if you use cut out flares you would be cutting out the rust.  No windshield, hood, motor, tranny rear end, leafs, doors, interior all gone.  I basically have the front suspension, steering, and cab shell.  Front axle is 3.55, the perches are rotted but rolls fine.  Springs look fairly new.  The cowl panel is there and so is the wiper assembly.  All for your best offers.
  • 5 weeks later...
I have an 88 comanche it just got rear ended, i am looking for the right rear quarter of a bed from tail light section to just forward of the right rear wheel arch, I figure I will just cut out the wrinckle and spot weld in the rear quarter instead of putting a complete rear 6 ft. bed. Please reply to: Mikeoconnell2@gmail.com  Thank you, I am also in Mass
Here is a picture of what I would be interested in.  I guess if you could cut it as close to the factory weld seam as possible on the bottom and back that would be preferred.  If you could go above that body line on the top it would make it easier to install.
Thanks a bunch, let me know if you have any other questions.  PM me with how much you want for it and to cover shipping and I'll give you my address as well.
Image Not Found
Archived
