williamMJ88 Posted June 5, 2013 Share Posted June 5, 2013 It is a 1988 Jeep Comanche MJ Amc 2.5L 150cid 5spd. 2wd Plans are engine swap. Maybe 4x4 later down the line. Thinking of a small lift here soon, I want 4x4 but i all ready have 2 of them, so kinda like a prerunner setup Which I'm trying to find a list of what i would need for the swap. Here are my swap ideas, 1. 4.0 swap, need to know a idea of what trans i can use, manuel or auto and if auto will i need the ecm and tcm and wireing ? 2. Chevy 4.3 or 5.7 swap, with auto trans, 700r or 350 turbo, and if i go with a chevy motor will i have to shortin the drive shaft? Thats what I have come up with, Thanks for any help. Here are some pics. Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted June 5, 2013 Share Posted June 5, 2013 A good manual trans for the 4.0 is a AX-15 If you want an auto tranny for the 4.0, you can also get an AW-4 By the way Welcome to the club!!! Link to comment Share on other sites More sharing options...
williamMJ88 Posted June 6, 2013 Author Share Posted June 6, 2013 Thanks. Kinda wanting to keep it a manual. I'm thinking a 4.0 maybe a little easyer to swap Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted June 6, 2013 Share Posted June 6, 2013 If you use the 4.0, you will have to do some firewall work to fit it in there. Link to comment Share on other sites More sharing options...
williamMJ88 Posted June 11, 2013 Author Share Posted June 11, 2013 Well I have decided to change some things up from what i wanted to do. Thinking adding 4wd, and a automatic trans, any advice on a trans that will work with my 2.5? Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted June 11, 2013 Share Posted June 11, 2013 You would have to get a 4x4 AW4 trans. As for 4 wheel drive you will need the front axle, more than likley a D30 and front drive shaft shift linkage etc... Youll have to shorten the rear drive shaft too. Link to comment Share on other sites More sharing options...
williamMJ88 Posted June 17, 2013 Author Share Posted June 17, 2013 Sorry to sound dumb, I have been looking around and I'm getting confused, 1st If i did a auto swap can i just add a tcm and be ok? 2, stay a manual, can i use my ax5 or another ax5? 3 can i keep my rear axle and just add the front, I'm just having trouble finding what i will need , Link to comment Share on other sites More sharing options...
k3rn4lkr45h Posted June 17, 2013 Share Posted June 17, 2013 you can keep the rear axle if you match the ratio for the new front axle. Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted June 18, 2013 Share Posted June 18, 2013 As long as the rear gear ratio is the same as the front, you are fine. If you wanted to have a manual transmission and have 4x4, you will need to find one with 4x4 capabilities. So instead of having a 2 wheel drive AX-5, you will need a AX-5 with 4x4, If you do put 4 wheel drive in. your rear drive shaft will need to be shortened. And your not sounding dumb, half of the stuff I didnt know I learned from the club. No one is dumb on here. :thumbsup: Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 7, 2013 Author Share Posted August 7, 2013 Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 13, 2013 Author Share Posted August 13, 2013 Looking for some info on the engine mount brackets on the engine of the 2.8. and any info where to get them.. I want to find out if they will fit the 3.4 chevy or a 4.3 Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 19, 2013 Author Share Posted August 19, 2013 Well we took the MJ to the Indiana state fair today, for the open car show. only had 2 jeeps out of 110 car/trucks. I won top 25, both jeeps did. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted August 19, 2013 Share Posted August 19, 2013 Great job @ the show....I also love taking the MJ's to shows. Nice lookin truck :thumbsup: Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 20, 2013 Author Share Posted August 20, 2013 Thanks, Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 22, 2013 Author Share Posted August 22, 2013 Will this fit my engine,,, They didnt change the 2.5 bolt pattern did they? AX-5 Transmission Bell Housing. No cracks or damage. Fits 97-02 Jeep 2.5L Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted August 24, 2013 Share Posted August 24, 2013 Should bolt right up Link to comment Share on other sites More sharing options...
williamMJ88 Posted August 25, 2013 Author Share Posted August 25, 2013 thanks Link to comment Share on other sites More sharing options...
williamMJ88 Posted December 23, 2013 Author Share Posted December 23, 2013 Havent done much to the truck. After the 1st of the year i will be doing some work on it. I'm looking at putting a tilt steering wheel in it, can i just get one out of a same year cherokee. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted December 23, 2013 Share Posted December 23, 2013 Yep XJ steering columns are interchangeable. :thumbsup: Link to comment Share on other sites More sharing options...
williamMJ88 Posted December 25, 2013 Author Share Posted December 25, 2013 thanks Link to comment Share on other sites More sharing options...
