Starter Sounds Like Cat Bieng Strangled
You can only shim a starter when it attaches to the block sideways, ala Chevy. The Jeep attaches from the front and to the best my knowledge cannot be shimmed. Check the solenoid attached to the top of the and make sure it's not sticking. Also check the starter over run clutch, that it's not sticking.
Now that my memories been refreshed, the book says use a pin gauge and check the clearance between the starter gear and ring gear. That is hard to do. I just start adding shims until any noise goes away. That is, it sounds right when engaging.
