istaywikkid Posted May 10, 2013 Share Posted May 10, 2013 my a904 has the fuel gauge where you see where you shift (Park drive and all that stuff) does anyone know where the clip goes? for the a904 3 speed auto trans in 1987 comanche pioneer Link to comment Share on other sites More sharing options...
Eagle Posted May 10, 2013 Share Posted May 10, 2013 What clip are you talking about? Link to comment Share on other sites More sharing options...
87manche1 Posted May 10, 2013 Share Posted May 10, 2013 Column shift? Should clip onto the shift collar somewhere Link to comment Share on other sites More sharing options...
87manche1 Posted May 10, 2013 Share Posted May 10, 2013 Been swapped?http://www.roadkillcustoms.com/hot-rods-rat-rods/Transmission-Cross-Reference-Database.asp?Transmission=904 Says 904 was last used in 86 or u have a mismatched end of model yr truck Link to comment Share on other sites More sharing options...
87manche1 Posted May 10, 2013 Share Posted May 10, 2013 Like this?http://www.virtualjeepclub.com/showthread.php?72689-Can-I-switch-my-instrument-cluster Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 10, 2013 Share Posted May 10, 2013 It does, the shift indicator cable clips on the intermediate column cover that moves when you shift. Also if it's an 87 you have the AW4; the a904 3-speed was only used in the 86 models. Unless you have an oddball. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 10, 2013 Share Posted May 10, 2013 The A904 was used behind the 2.8 and I assume the 2.5 in 86. What auto was used behind the 2.5 in 87 and later? Or did 2.5's not have an auto option in those years? Link to comment Share on other sites More sharing options...
istaywikkid Posted May 10, 2013 Author Share Posted May 10, 2013 @87manche1 yes thats what I'm talking about. and yea i have a 87 with the 4.0 but i have this stupid 3 speed auto and i have no idea why :/ its original to never had a motor or tranny swap. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 11, 2013 Share Posted May 11, 2013 The A904 was never offered behind the 4.0. The A999 and TF727 which is related to the A904 was offered behind the 258 and AMC V8s in the full size Jeeps and would only be in a 4.0 Comanche if someone swapped one in. Are you sure you don't have the AW4 and its just not getting into 4th? The AW4 has a long rectangular oil pan, the A904/A999 has a more squarish pan if I remember correctly. Let make sure we know what you have. Link to comment Share on other sites More sharing options...
istaywikkid Posted May 11, 2013 Author Share Posted May 11, 2013 my dad said thats what it is, he said it could be a special order or just a throw together. my build date was September 86 On 5/11/2013 at 3:08 AM, dasbulliwagen said: The A904 was never offered behind the 4.0. The A999 and TF727 which is related to the A904 was offered behind the 258 and AMC V8s in the full size Jeeps and would only be in a 4.0 Comanche if someone swapped one in. Are you sure you don't have the AW4 and its just not getting into 4th? The AW4 has a long rectangular oil pan, the A904/A999 has a more squarish pan if I remember correctly. Let make sure we know what you have. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted May 11, 2013 Share Posted May 11, 2013 Maybe you can take and post a pic of the trans pan for us to ID for you. Link to comment Share on other sites More sharing options...
