1987Comanche Posted May 4, 2013 Share Posted May 4, 2013 '92 MJ, 4.0 HO, 2WD, AX-15, just a hair under 250K miles. I've been working my way through the front suspension and have done Upper & lower control arm bushings, track bar, sway bar end links. Shocks appear to be fairly new & I'm sure the ball joints are OEM. Tie rods look OE but seem tight. I replaced the steering damper last week and, shortly thereafter, a single "pop" appeared. It's not 100% consistent (I don't think any symptoms on a Jeep ever are...) but 50% of the time I'll get a single pop when I reverse direction (back out of a parking spot), or decelerate/accelerate (get off the hwy, etc). This started after changing the steering damper but, offhand, I can't understand why that would cause a pop. It could be a coincidence that it started after changing the damper, then again perhaps not. Any thoughts? Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 4, 2013 Share Posted May 4, 2013 Take the damper off and go for a drive. Then you'll know. Link to comment Share on other sites More sharing options...
Comanche County Posted May 4, 2013 Share Posted May 4, 2013 Yeah, check the dampener, also ensure the track bar bracket bolts are nice and tight. Link to comment Share on other sites More sharing options...
1987Comanche Posted May 5, 2013 Author Share Posted May 5, 2013 I played around with it a bit today and noticed the TREs rock from front to back easily & can contact the spindle. The boots are in rough shape but are more or less intact. I greased them up and one shot out a wad of hardened goo (I wouldn't call it grease). TRE's seem to be dampened by the fresh grease and are much harder to rotate into the spindle. A short drive showed some improvement so we'll see what happens. Link to comment Share on other sites More sharing options...
