dhisso Posted May 3, 2013 Share Posted May 3, 2013 Hey I have a 2.5L 2wd Jeep comanche and I am able to get a 89 jeep with a 4.0 and 5 speed 4wd. I was wondering if I could just bolt up the transmission from the 4.0 to the 4cyl? Is it a different bell housing? Different input shaft? I was just wandering. Link to comment Share on other sites More sharing options...
TheDirtyJeep401 Posted May 3, 2013 Share Posted May 3, 2013 Bell housing I believe is different, Input shaft I thought was the same but I could be wrong. Link to comment Share on other sites More sharing options...
AeroNautical Posted May 3, 2013 Share Posted May 3, 2013 Wasn't the gearing slightly different between the 2.5 and 4.0 transmissions? Like how you can get different diff gearing. Link to comment Share on other sites More sharing options...
Geonovast Posted May 3, 2013 Share Posted May 3, 2013 No. Well.... mostly no. They're not even the same transmission. 2.5 uses the AX-5, 4.0 uses the BA 10/5 and AX-15. Not the same bolt pattern. It is possible to bolt an AX-15 to a 2.5, but it requires an elusive Dakota bellhousing and some fab work. If you're picking it up for a 4wd swap, nothing we be of use to you. If you currently have the 2.5 with a 5 speed, your rear gearing is going to be 4.10. 4.0/5 speed combo got 3.07, so the front axle would also be useless to you. Link to comment Share on other sites More sharing options...
dhisso Posted May 7, 2013 Author Share Posted May 7, 2013 Well unfortunately I had the 4-speed trans.. So 3.55 gearing. So I should just keep a lookout for a ax-5 from a yj. Do you know if the 5 speed trans from a newer model TJ would work? Or is that a different bolt pattern too? Link to comment Share on other sites More sharing options...
Geonovast Posted May 7, 2013 Share Posted May 7, 2013 All AX-4s and AX-5s use the same bellhousing pattern. The issue with the TJ trans is the T-case clocking, but should work fine for you. Link to comment Share on other sites More sharing options...
mvusse Posted May 7, 2013 Share Posted May 7, 2013 The YJ and TJ transmissions clock the transfer case up higher causing interference with the floor. You want an AX5 out of a 4wd Comanche (MJ) or Cherokee (XJ). Link to comment Share on other sites More sharing options...
dhisso Posted May 8, 2013 Author Share Posted May 8, 2013 Okay thanks guys! I have a ax-5 and tcase I'm looking at from a yj that is still running and driving today so I might be getting that! One more question will a TJ 231 fit behind the ax-5? Link to comment Share on other sites More sharing options...
Eagle Posted May 8, 2013 Share Posted May 8, 2013 Okay thanks guys! I have a ax-5 and tcase I'm looking at from a yj that is still running and driving today so I might be getting that! One more question will a TJ 231 fit behind the ax-5? If the tranny you're looking at has a transfer case, why would you be looking for another transfer case? Keep in mind that the transfers case linkage in the YJs attached directly to the transfer case, whereas in the XJ and MJ it attaches to the floor. To use the transfer case shifter that will be in the YJ you will have to butcher the floor (transmission tunnel) of your MJ, PLUS cut off the top of the transfer case shift lever to avoid interference with the dashboard. To use a YJ trans/xfer case combo in an XJ or MJ you still need an XJ/MJ transfer case shifter mechanism to do the job halfway right and neatly. Link to comment Share on other sites More sharing options...
dhisso Posted May 8, 2013 Author Share Posted May 8, 2013 O yes I knew I need to get the shifter linkage for the transfer-case. I still need a front axle, and drive shafts. Just collecting one part at a time, and as for the tj case I have a few different options for a transmission and just incase this deal falls through I have another ax-5 and a nv3550 out of a tj I can get. So I was wondering if I get the ax-5 without the transfer-case will a tj case bolt up? Link to comment Share on other sites More sharing options...
Geonovast Posted May 8, 2013 Share Posted May 8, 2013 NV3550 won't do you any good. That's a 4.0 trans. There's no difference when it comes to XJ/MJ/YJ/TJ cases, except for the generational differences that come with model year. The differences you're going to be worried about is spline count and input shaft length, but if you get a case from another AX-4/5, it'll bolt up to any AX-4/5. Link to comment Share on other sites More sharing options...
dhisso Posted May 8, 2013 Author Share Posted May 8, 2013 Okay cool that's all I need thanks guys! I hoping to get the ax5 and tcase combo to make everything easier! Link to comment Share on other sites More sharing options...
