ComancheJon Posted May 2, 2013 Posted May 2, 2013 Alright, so I recently got my hands on an 86 comanche long bed. It had the 2.8 with the auto and 4wd in it. The guy pulled the whole drivetrain to swap in a 92 cherokee 4.0, aw4, and np242. I just ran across a huge problem and don't know how to get around it. The engine seems to be sitting completely correct, yet the transmission/trans mount do not line up with each other. There is set mounting places for the crossmember, as you guys probably know. I posted on cherokee forum already, but I thought I should post here as well. We tried using whatever the crossmember it is that he gave me, and the 93 crossmember from my cherokee. I am using a trans mount for a 92 comanche with the 4.0, auto, and 4wd.
onlyinajeep726 Posted May 2, 2013 Posted May 2, 2013 The '86 XJs and MJs were never designed to fit a 4.0L. The firewall where the transmission tunnel starts sits lower than the '87 and newer models. You basically have to modify a lot of the Jeep to make it fit right. There's tons of information about a 4.0L swap into the '86 and older XJs and MJs on this forum and a few others. It can be done, and eventually I'm going to do so on mine. But it's not a direct swap... Here's the thread I started: http://comancheclub.com/topic/38356-40-into-an-86/ And here's a comparison of the firewall/transmission tunnels. This will also address your crossmember question. http://comancheclub.com/topic/31039-big-swap-help/?p=314518
ComancheJon Posted May 2, 2013 Author Posted May 2, 2013 So it depends upon the application when it comes to firewall modification but the crossmember absolutely has to be moved back? That's what I'm getting from multiple people's answers
