Hello, I have the opportunity to pick up an Optima yellow top battery at a good deal. Does anyone know which size battery will fit best in the stock tray?
I'll be running a Warn M8000 winch and a CB FYI
The optima web site is kind of strange... When you do a make and model search there is no comanches listed and the first year cherokees show up is 98
The recomended yellow top battery for a 98 cherokee is a
OPTIMA® Batteries 8014-045 D34/78 YELLOWTOP® Starting & Deep Cycle
Battery Dimnensions are
Length: 10.06 in
Width: 6.94 in
Height:7.88 in
Is this a good choice?
Thanks, I just wasn't sure that perticular battery would clear the hood, thought it might be to tall. Thanks for the help!
It clears the hood just fine. The only thing that might not work is the stock tie-down. I can't remember for sure or not how I had mine held in place since it's been a few years since I had that truck.
I got yellow tops in both of my jeeps. An 88 manche and 96 cherokee. They fit without a problem and I reused the stock tie downs. The only thing i noticed is that they are a little small for the battery box.
