You cannot run an electronic speedo in a Renix with the factory equipment.  It's not like you can just swap out the cable speedo for an electronic one.
If it's the older style sender, the electronic portion simply unscrews, and you screw on a cable.  If it's the newer one piece, simply take out the bolt, pull out the sender, and put a cable one in.
