DIY battery relocate
How big of an ANL inline fuse should I use? Would linline be best or should I use another method?
Thanks,
Tom
you'll want to put that in the engine compartment, on the lead from the alt to the bat. You can't put one in on the batt lead to the starter.
stock alt output is 90 amps IIRC, so I'd go with a 100 amp or so fuse.
at least that way you'll cut the alt's circuit, and not end up welding the cable to your frame.
Ok so just to make sure I do this right. I should use #2 welding cable to go from the alternator to the battery and then a 4awg to go from the starter to the battery. Use a (in my case I have a 105amp alt instead of the stock 65IIRC) 120amp inline ANL fuse between the alt and the battery. Then for the ground run again a #2 welding wire from the ground on the battery to say the frame under the bed?
feerocknok: how did running that ground to under the seat mess up your electronics?
Thanks,
Tom
Basically too long of a ground created too much resistance similar to a bad ground. I'm running 2 Gauge, so maybe 0 would do the trick, but it's money in the can if you ask me versus grounding to the frame and having a nice motor to frame ground. Currently all of my lights are like a campfire, both in amplitude and consistency.
i'm using #2 from negative battery to frame . #2 from positive to starter. # 2 from engine to ground. #6 wire from alternator to battery. some kind of fuse my mechanic says to use in the alt to batt wire. i just was at my mechanics, they both said, don't use any fuse on that circuit. you would be screwed if it went when your off road. you rarely have a cable go bad. better to , like i'm going to do, slide the cable down water hose, and clamp it every 12 in to the frame. :popcorn:
