Which Flywheel Should I Get
I have an 86 Jeep Comanche X 2.5 L With a AX-5 transmission This site has two but they have different sizes and I'm not sure which one I should get, Or which one would be better for off-road if they both fit
Here's a link if you want look at the site yourself thank you
http://www.partsgeek.com/catalog/1986/jeep/comanche/clutch/clutch_kit.html
You only need to change the flywheel if the clutch got so bad that it damaged the flywheel.  If your clutch has been slipping a lot, it may be a good idea to change it.  If you're just changing the clutch because it's old and just started to slip, you shouldn't need to change it.
Clutch kit will not come with a flywheel.
