littlezeeker Posted April 4, 2013 Posted April 4, 2013 I have an 86 Jeep Comanche X 2.5 L With a AX-5 transmission This site has two but they have different sizes and I'm not sure which one I should get, Or which one would be better for off-road if they both fit Here's a link if you want look at the site yourself thank you http://www.partsgeek.com/catalog/1986/jeep/comanche/clutch/clutch_kit.html
huck731 Posted April 4, 2013 Posted April 4, 2013 if you have and orielly's auto nearby, they have a clutch kit for $75. ( I'm pretty sure it's a clutch master btu not 100%)
littlezeeker Posted April 4, 2013 Author Posted April 4, 2013 From what I understand the flywheel has part of the clutch disk on it ? So if your clutch goes bad you need to change your Flywheel will also
Geonovast Posted April 4, 2013 Posted April 4, 2013 You only need to change the flywheel if the clutch got so bad that it damaged the flywheel. If your clutch has been slipping a lot, it may be a good idea to change it. If you're just changing the clutch because it's old and just started to slip, you shouldn't need to change it. Clutch kit will not come with a flywheel.
jimoshel Posted April 4, 2013 Posted April 4, 2013 Check the size of your old clutch and replace it with the same size.
