hitman72 Posted March 26, 2013 Posted March 26, 2013 I have an 88 4.0L with the ba10/5 5 speed. When i am on the freeway and get up to 65mph in fifth gear there is a strange sound that comes from what sounds like the where the shift lever enters the top of the tanny. Sounds like someone put a bunch of BBs in a can and the shook it on a paint shaker, high pitched. If i put my hand one the shifter and apply pressure in any direction it goes away (very little pressure). Also if i let off the gas it goes away (while still in gear) What do you guys think. The car still drives fine it is just super annoying :fs1:.
JFAComanche6 Posted March 26, 2013 Posted March 26, 2013 Mine makes a noise like I've got a chain dragging under my tranny in 5th gear. And it sounds like I have a supercharger in gears 1, 2, and 3. I figure I'll just drive it until there's some kind of problem, then I'll have to do some improvisions to the 2wd tranny I still have if I can't find a 4wd 10/5.
Geonovast Posted March 26, 2013 Posted March 26, 2013 I would check the fluid level of the trans and the T-case.
JFAComanche6 Posted March 27, 2013 Posted March 27, 2013 My transmission holds fliud good but the t-case definately leaks. I usually keep both pretty full.
hitman72 Posted March 27, 2013 Author Posted March 27, 2013 Ya as of just a few hundred miles ago they were both fine. This noise has been there since i bought the truck. It seems to only do it when the trany is nice and warm, this morning i drove it about 30 miles city/highway and it did not do anything. IDK what to think, lol
JFAComanche6 Posted March 27, 2013 Posted March 27, 2013 If it doesn't cause a problem, I won't try to do anything about it. I've figured that much out so far haha
