Blue88Comanche Posted March 25, 2013 Posted March 25, 2013 I know somewhere on this forum it the info i need and have tried to find it without any luck. We too dads MJ up to the shop to get the ac running again.. Saturday we drove about an hour with the ac on after it rained and water started coming from the dash, The MJ has not leaked prior to refilling the ac so i dout its rain water leaking in. but i remember heading here that there was a little hose that allows the condensation from the ac through the firewall and to outside.. I just can't locate that tube to clean it...
Akula69 Posted March 25, 2013 Posted March 25, 2013 Inside the engine compartment straight down from the heater core inlet/outlet at the bottom of the firewall where it meets the passenger-side frame rail. Your view of the hose may be blocked by the charcoal vapor tank. On some models the darn outlet is inside the passenger-side frame rail (only seen this once) and you have to use a coat hanger to clear it. Be sure and bend a (very small) loop at the end of the hanger, as the hose is soft rubber.
