mjbret13 Posted March 10, 2013 Share Posted March 10, 2013 Just joined Comanche club today sing I bought my first Comanche 2 weeks ago with a cracked head. Since then I've gotten a new head on. Now here's the problems. There was no power to anything. The relays would click and motor will crank but everything inside cab is dead. List of dead Gauges Hvac Radio Cluster lights Warnings Hazards Brake lights Parking lights Interior lights Turns So far replacing fuses have fixed Brake lights Gauges Warning lights Turns Radio Glove box light works now also. There is still no gauge lights or parking lights. Link to comment Share on other sites More sharing options...
lamart72 Posted March 10, 2013 Share Posted March 10, 2013 Check all of your grounds to make sure you didn't miss one. Link to comment Share on other sites More sharing options...
zackcj7 Posted March 11, 2013 Share Posted March 11, 2013 Sounds like your headlight switch needs attention next. Link to comment Share on other sites More sharing options...
mjbret13 Posted March 11, 2013 Author Share Posted March 11, 2013 Yesterday I got my head lights and markers working. Had to get rid of the head light switch and use a toggle. Triggers the factory relay for markers and the relays in the homemade headlight harness. Also ran new wire to the gauge lights and climate controls. I have cleaned all the grounds and added grounds. If I get another factory head light switch connector I can get it re installed. Wasn't thinking when I cut one of the wires too short from the plug to splice back in. Link to comment Share on other sites More sharing options...
