Hello all, i bought my 1st comanche yesterday and all of the signals DID work except for the front left.. it would stay on continuously no matter what, aslong as the headlights were on, and the hazard lights wouldnt do anything... now today NONE of the signals work, and the front left still stays completely illuminated aslong as the headlights are on, and the hazards also still don't work, and now i have noticed the interior arrow lights no longer light up and no longer makes the clicking noise when you turn.
Ive ripped right into the dash, check all of the relays, fuses appear to be good, etc
if anyone can give me some helpful advice on how to get my signals working it would be greatly appreciated
Thanks fellow Comanche owners!!
Look closely at the bulbs in the rear tail lights and mahe sure the correct bulbs are in the corresponding sockets. Mine did the same thing, and I found someone had installed an 1156 into an 1157 socket.
everything appeared to be good in the rear tail lights.. i never check for any numbering but they worked fine the other day.. brake lights, and hazards all still function all the way around 4 corners.
sounds like maybe your multifunction switch is bad, or your sockets up front are bad. Both parts are available at NAPA.
really, you think its possible that the front sockets are bad... because they are lighting up.. (both filaments) just only flashing when the hazards are on.. and when i flick the multifunction switch nothing happens.. i also think it could be the multifunction because my wipers only work on 1 speed.
Thanks for your info!
When those sockets go bad (lose a ground etc...) strange things can happen. Probably not the problem, but they are inexpensive and easy to swap, so I always start with the easy stuff. Clean the grounds, connectors etc...
Speaking of connectors, there is the one on the driver side inner fender near the front that controls the front lights. Wouldn't hurt to clean it.
