flint54 Posted March 6, 2013 Share Posted March 6, 2013 Just when I thought things were running too good to be true. Started running like crap the other day, with A/F ratio wild swings. Fault codes listed: 12, 13, 14, 13, 55. (Not sure why 13 shows twice). All this started right after I replaced my old tired battery, Checked manifold vacuum, it's solid 20 with thottle-induced swings as should be. Installed new MAP sensor. No joy. Motor sputters and fouls out when A/F is overly rich (as one would expect) and and stalls out, with high RPM cutout, when overly lean (as one would expect). And once in a while it runs fine. My O2 sensor was replaced just a few months ago, the A/F meter runs off a separate sensor. Suggestions? Link to comment Share on other sites More sharing options...
flint54 Posted March 6, 2013 Author Share Posted March 6, 2013 And I don't know why this posted three times??? Link to comment Share on other sites More sharing options...
cruiser54 Posted March 6, 2013 Share Posted March 6, 2013 MAP sensor on the firewall? If so, how is the vacuum going to it? Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 6, 2013 Share Posted March 6, 2013 Also, what's your MAP input voltage reading? As referenced to the MAP sensor ground pin, not chassis ground. Link to comment Share on other sites More sharing options...
flint54 Posted March 6, 2013 Author Share Posted March 6, 2013 Yes, the MAP sensor on the firewall. Vacuum supplied via hard plastic tube directly from the manifold, connected with two very short rubber hoses. These are all new. There is nothing else tied into that line. MAP sensor input voltage, referenced to the MAP sensor ground pin, (and measured with plug connected through the wire jacket) is 4.95V, very close to what it should be. Also, the ECU connector was recently (last fall back) pulled, cleaned, and pins checked. Link to comment Share on other sites More sharing options...
Akula69 Posted March 6, 2013 Share Posted March 6, 2013 One item that I found when this was "my" problem was that the throttle body had fouling the area where the hard line went into rubber fitting. It was interfering with the vacuum going to the MAP. Cleaned using carb cleaner and re-installed. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 6, 2013 Share Posted March 6, 2013 I had a code 14 for awhile (input voltage was 5.1V) but a new GM MAP sensor, not aftermarket, got rid of that code. I've never had a code 13 though. You have probably done this already, but how are the MAP output voltages while running, and did you check for continuity between the MAP output connector wire and the ECU pin? Link to comment Share on other sites More sharing options...
flint54 Posted March 18, 2013 Author Share Posted March 18, 2013 Had to set this aside for a while, but back on it now. The MAP sensor voltage output is 4.83v, way too high. I suppose it is possible for both the original and the replacement sensor to be failed, but seems unlikely. I'll check the line continuity tomorrow, but doubt that would explain the high output voltage. The vacuum is good, right at the sensor. I'm seeing A/F around 8 until warm, then 12-14 except when thottle is closed then it goes full lean (18). Link to comment Share on other sites More sharing options...
