Whisslaren Posted February 17, 2013 Share Posted February 17, 2013 Hi people! I'm getting closer to when it is time for axle change. Anyone know roughly how much lift I will need in front to clear 37" tires and still have decent flex? The rear is not an issue since it will have custom bed and frame Also if anyone could tell me how to measure how much lifted it is right now, it would be great Thanks Lord Whistleton Link to comment Share on other sites More sharing options...
Jakesjeepmj1988 Posted February 17, 2013 Share Posted February 17, 2013 I'm gonna guess around 8 inch lift and if you use long arms you should still flex good but i like really high trucks to me the more lift the better Link to comment Share on other sites More sharing options...
Dirteatr717 Posted February 17, 2013 Share Posted February 17, 2013 I've seen as low as 3" lift on an xj that was bumpstopped correctly and performed very well. I'm currently around 5" of lift and could fit a 37" fine if I trimmed a little more. I'm also going to be running 37s on fullwidths within the next couple weeks. Here is Cherokee chiefs Manche on 37s with around 5.5" of lift. http://comancheclub.com/topic/36012-cherokee-chiefs-89-lwb-pioneer-build/page__st__40#entry374335 Link to comment Share on other sites More sharing options...
mvusse Posted February 18, 2013 Share Posted February 18, 2013 I ran 6.25" out front with 35" tires and ended up hacking the crap out of my fenders to clear the tires. Moving up to 37"s now, but will have a full width axle, low backspacing wheels and the way the springs mount will give me an additional 1" lift. Link to comment Share on other sites More sharing options...
comanchedude Posted February 19, 2013 Share Posted February 19, 2013 I have 35" tires with 6.5" springs. you will need to bump stop obviously. also flatten out the seem in the wheel well... at 37 you will start to get into the wheel well when you turn so you will have to clearance that more than just flatting the seem. I say 6" min and make room... Link to comment Share on other sites More sharing options...
Goose Posted February 19, 2013 Share Posted February 19, 2013 Who needs fenders. A buddy of mine is making his front fenders out of tj flat fenders. Link to comment Share on other sites More sharing options...
Whisslaren Posted February 19, 2013 Author Share Posted February 19, 2013 Thanks for the tips. I'll go for around 7" inches then and if needed som massage of the wheel well. I have some really special fenders in store for it as well. Did any know how I could measure how far from stock it is right now? Cheers Daniel Whistleton Link to comment Share on other sites More sharing options...
Garvin Posted February 20, 2013 Share Posted February 20, 2013 With no cutting and without rubbing, 9+ inches. It comes down to as much as you want to cut to as low as you can go. Right now my Comanche is set up for 6" of lift with 42" tires with 4" up travel and 8" down (right now only running 38.5's since I'm waiting for the right set to pop up or I win the lottery). Both my front and rear are cut up to the body lines though as well as both axles are stretched (3" front and 5" rear stretch). Link to comment Share on other sites More sharing options...
