Need Lower Rear Cab Sheet Metal
MJRemi
If anyone has a MJ that is destined for scrap, I need the section of the cab from the door jamb to the back and from bottom up to the body line that is just below the door handle. I was going to cut the section from my parts truck but someone is buying the cab/frame to build a JeepSpeed racing truck and they need that section. I already have a replacement bed so I just need the corner section.
I'd recommend getting it youself.
I posted a thread for a cab corner awhile back and got no responses, so I went down to the pull-a-part and looked at a Comanche they had there. The cab was good, and when I asked the manager how much he would sell the corner for he said $20.00. Cut it off using a 18 volt sawsall and went thru 4 blades doing it - took about 30 minutes. The cut was made along the inside of the doorframe up to about 1/2 way from the trim line under the handle across the cab until the pinchweld below the rear window corner, down the back and finally inside the pinchweld right along the bottom uniframe member.
When I got back to the desk the manager was there, looked at what I had and told the clerk $10.00. :yes:
Now I have to figure out how to flange the edges, and I'll be good.
No help sourcing a corner,
but since Akula asked,
I swapped cab corners on my trail MJ
http://comancheclub.com/topic/14128-my-9-year-build-so-far/#entry140759
Mine was stuffed too,
maybe a little worse than yours Remi,
but I didn't cut the whole thing out
Got a cheap Harbor Freight flanger,
and put the seam behind the vent
