Seatbelt Interchange For Comanches
Wrz
Anyone know the interchange for the seatbelts? I'm in the process of redoing my interior and found a good deal on a set of 1986 black ones. My trucks a 1990
Thanks and any info or tips would be appreciated
The several sets I've had had a distinction. The 86 latch is narrower than the 87+ so you would have to switch both latch and receiver belts. Another issue I ran into was trying to mount the pillar belt assembly from an 86 into a 88 and found the 86 bracket was too long for the indented sheet metal mounting area, however, that 86 set was from a Cherokee. If the 86 set is from a MJ, it should work.
Thanks for the response, I've been searching for awhile for some info. I'm going to order them tomarrow and post my results when I get them
Thanks
I swapped 89 comanche belts into my 88 comanche. Everything was fine. If you don't mind me asking how much are you going to pay? I was going to buy a black set but I ended up spray painting mine flat black because I couldnt find any.
I work at a jy so I always get the jy prices which are usually a lot cheaper, I'm going to give them a call tomarrow and see ow much they want for everything
Will keep posted
