54bobby Posted February 7, 2013 Posted February 7, 2013 http://southjersey.craigslist.org/pts/3557574521.html
mvusse Posted February 7, 2013 Posted February 7, 2013 Not all D44s are created equal. This one uses 6 lug axles so you would need adapters, different wheels front and rear, or replace the front axle as well. And 3.13 gears are not the best so you're looking at a regear too, probably in the range of $300 for parts plus $500 labor. So that axle will cost you over $1K....
54bobby Posted February 8, 2013 Author Posted February 8, 2013 Not all D44s are created equal. This one uses 6 lug axles so you would need adapters, different wheels front and rear, or replace the front axle as well. And 3.13 gears are not the best so you're looking at a regear too, probably in the range of $300 for parts plus $500 labor. So that axle will cost you over $1K.... learning more every day.
jpnjim Posted February 9, 2013 Posted February 9, 2013 And full size Waggy rear axles are actually narrower than ours. XJ/MJ/YJ/ZJ axles = ~60.5" Narrow Track FSJ rear axles = ~58"
